Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I just put in the shitty ECS ELITEGROUP mobo and i cant get it ungrounded. I put it on cardboard and it beeped out of the case (with nothing on the board except processor) and once i put it back in the case NOTHING please help.
i have the same problem, my mobo works outside of the case but when i put it inside nothing happens. Any help would be appreciated, this is starting to get frustrating!
Check to make sure one of the motherboard standoffs isn't aligning with a hole. Or, the motherboard standoff doesn't have a hole on the motherboard and is grounding out...
The biggest problem with shorting out a mobo in the case is using larger than usual screws on the standoffs and touching a trace with the screwhead. I got in the habit of using insulated washers on both sides to eliminate that possibility.
