unexpected type error in java
S
SpeedRunner
Guest
I've tried everything I could but I can't get line 128 to work for ANYTHING.
Code:
C:\Documents and Settings\Marshall\My Documents\My Downloads\RosterTest.java:128: unexpected type
required: variable
found   : value
				 prev.setNext(cur) = cur.getNext();
1 error
Tool completed with exit code 1
Code:
import javax.swing.*;
public class RosterTest
   public static void main(String[] args)
      String input;
      Roster myRoster = new Roster();
      do
         input = menu();
         if(input == null || input.equalsIgnoreCase("q"))
            JOptionPane.showMessageDialog(null,"Goodbye!");
         else if(input.equalsIgnoreCase("a"))
            doAdd(myRoster);
         else if(input.equalsIgnoreCase("f"))
            doFind(myRoster);
         else if(input.equalsIgnoreCase("r"))
            doRemove(myRoster);
         else if(input.equalsIgnoreCase("l"))
            JOptionPane.showMessageDialog(null,myRoster);
         else
            JOptionPane.showMessageDialog(null,"Invalid - try again!");
      }while(input != null && !input.equalsIgnoreCase("q"));
      System.exit(0);
   public static String menu()
      String s = "MENU\na - add\nf - find\nr - remove"
         + "\nl - list\nq - quit\nEnter a letter:";
      return JOptionPane.showInputDialog(s);
   public static void doAdd(Roster myRoster)
      String name = JOptionPane.showInputDialog(
            "Enter student name:");
      int number = Integer.parseInt(JOptionPane
         .showInputDialog("Enter student number:"));
      double gpa = Double.parseDouble(JOptionPane
         .showInputDialog("Enter student gpa:"));
      boolean added = myRoster.add(new Student(name,number,gpa));
      if(!added)
         JOptionPane.showMessageDialog(null,"Student with number " +
            number + " already exists!");
   public static void doFind(Roster myRoster)
      Student foundStu = myRoster.find(number);
      if(foundStu == null)
         JOptionPane.showMessageDialog(null,"No student with number "
            + number + "!");
      else
         JOptionPane.showMessageDialog(null,foundStu);
   public static void doRemove(Roster myRoster)
      Student removedStu = myRoster.remove(number);
      if(removedStu == null)
            + number);
      else
         JOptionPane.showMessageDialog(null,"Removed student: " + removedStu);
class Roster
	 private Student head;
	 public Roster()
	 public Student find(int toFind)
		 Student cur = head;
		 while(cur != null)
			 if(toFind == cur.getNumber())
				 return cur;
			 cur = cur.getNext();
		 return null;
	 public Student remove(int toKill)
		 Student prev = null;
		 Student cur = head;
		 while(cur != null)
			 if(cur.getNumber() == toKill)
			 prev = cur;
			 cur.getNext();
		 return null;
    public boolean add(Student addStu)
		 Student cur = head;
		 while(cur != null && addStu.getNumber() < cur.getNumber())
			 prev = cur;
			 cur.getNext();
		 addStu = cur;
		 prev = addStu;
		 return false;
	 public String toString()
		 return null;
class Student
    private String name;
    private int number;
    private double gpa;
    private Student next;
	 public Student(String nam, int num, double g)
		 name = nam;
		 number = num;
		 gpa = g;
    public Student getNext()
        return next;
    public int getNumber()
		  return number;
    public void setNext(Student n)
        next = n;
        return(name + number + gpa);
I'm well aware that the variable needs to be sent with the method call... I just cannot figure out a good variable to put in there. The only thing that makes sense is a value, not a variable! I cannot edit anything above the Roster class, by the way.
I'll post just the method to make it alittle bit easier to see.
Code:
		 Student cur = head;
		 while(cur != null)
			 prev = cur;
			 cur.getNext();
		 return null;
Your LValue (the value on the left of the assignment) is a function call. You can't do that - it must be a variable. Perhaps you mean to do something like setNext(cur.getNext()), or perhaps overload setNext to take two variables: the object that the value should be inserted after and the value to be inserted, i.e. setNext(cur, cur.getNext())?
Thanks, I had just figured that out a few minutes before you posted it. :)
