Hello all,
My current audio setup is a Creative Audigy 4 Pro card hooked up through a Logitech X-540 speaker system in Vista. My primary uses for it involve music listening and watching movies, although I do game occasionally.
A while back, I noticed that certain parts of audio would gain a sinusoidal power effect... the volume would raise and lower itself for (as best as I can tell) the low-mids only. It was inconsistent at first, but now it's a constant effect. In most cases it's only noticable when you're listening for it, but in some scenes with a constant audio output (such as rain scenes) it's definitely distracting.
Any clues as to what the problem is? Since I'm looking to upgrade my whole system anyway, it might be time to move on to a better sound card/speaker set. The PSU is also not the problem by the way... I've been able to observe this effect on 3 different PSUs since it started.
Let me know of any other tests I should try out, and also any recommendations for upgrading components. Thank you.
