Hi Everyone,
Here is a question for you tech experts. Can a power supply that is undervolting cause any damage to PC components? If so, what would likely be damaged? CPU, Video Card, Memory, etc? If damage can result then is it possible that a component would still fuction but exibit strange anomiles like graphic or data corruption? Also would it matter how long the system was running with this situation, for example several months or would damage occur within a small amount of time?
The reason I am asking this question is because I just recently found out that my Antec True Power 550 has been running with the +12 and +5 volt rails low. The 12v rail was dipping to 11.855 and the 5v rail was dipping to 4.811.
Thanks!
Mark
Thanks!
Mark
