Trying to heat my room and mine some Bitcoin while I'm not gaming... to get a little better temps I dropped the frequency and voltages to keep temps down then steadily increased to find a good compromise between heat and Mhash/s.
At 850mhz my card will stay at 1.000v and will set at 66C with fans at 66% which is plenty tolerable.. The second I click 851 voltage goes to 1.081 and temps will hover around 76-77 with the fans at annoying levels and 68F room temp.
I'd like to run stock clocks at say 1.040 so I keep it at around the same temps but lower fan speeds, but using sapphire trixx doesn't seem to let me undervolt, only overvolt.
Also, voltage adjustments don't show up in afterburner despite numerous "fixes" I've found online.
Any ideas?
EDIT: forgot to say the card is an XFX DD 900
Any ideas?
