Psycrow
- Feb 26, 2010
I have a i9 11900k cpu and a asus maximus extreme XIII board.
Currently my pc runs fine and has no problems.
But i have seen some videos where they undervolt this cpu to reduce heat and now im hooked on that.
My bios knowledge on OC and undervolting is rusty but after a quick reseach then it says i need to change the cpu to a offset value and choose - negative value
So i tryed to set the value for 0.0100 and it dosent change anything in the stress test. I still gets the same temps.
Using cpu z then i see the volt goes to max 1.280 v ish under load.
Currently im using windows balanced power, so the cpu idles when im afk.
The mhz does jump from 800 mhz to 5100 mhz using 1.488 ish volt when it peaks 5100 mhz
So am i doing something wrong here since nothing changes ?
Or can someone enlight me how to lower the volt and get better temps ?
Using air coolers prolly wont give me alot but anything helps in this horrible summer heat !
