undervolt on the 5v rail
fan_83
guys,
i just downloaded and installed a couple of sensor programs and i got a qestion.
both sisoft sandra and speedfan reported my rails as follow
3.3v = 3.31
5v = 4.27
12v = 12.29v / 11.79v
the first 2 are consistent with what speedfan and sisoft is reporting only the 12v rail is different. my worry is on the 5v.
with both programs reporting a 15% undervolt, can someone tell me whats the downside of undervolting on the 5v rails, and what items draw power from the rail
thanks
fan_83 said:
guys,
That's because both programs get the information from the same chip on your motherboard.
fan_83 said:
3.3v = 3.31
5v = 4.27
thanks
I'd say whip out a DMM because anyone is going to tell you that health-mon chips are inaccurate and that it's getting it's readings via a single trace from a single wire off the PSU.
If you should be concerned with anything it's that your software is telling you that you have a half a volt fluctuation on your 12V rail.
