Hi there,
I have just bought a couple of new hard drives. I have done a full format of them both, and now I am having trouble understanding the values of the S.M.A.R.T. attributes. I was hoping you might be able to help me out. I have copied the values from CrystalDiskInfo.
Here is the system drive and one of my new drives, and further down I will paste in the second drive (CrystalDiskInfo can apparently not see both of the hard drives in my double-slot external case).
CrystalDiskInfo 5.0.5 (C) 2008-2012 hiyohiyo
Crystal Dew World : http://crystalmark.info/
OS : Windows 7 Ultimate Edition SP1 [6.1 Build 7601] (x86)
Date : 2012/11/18 18:59:07
-- Controller Map ----------------------------------------------------------
+ ATA Channel 0 (0) [ATA]
- Hitachi HTS541616J9SA00 ATA Device
- ATA Channel 1 (1) [ATA]
- ATA Channel 2 (2) [ATA]
- HL-DT-ST DVDRAM GSA-T20N ATA Device
+ Intel(R) ICH8M Ultra ATA Storage Controllers - 2850 [ATA]
- ATA Channel 0 (0)
- ATA Channel 1 (1)
+ Standard AHCI 1.0 Serial ATA-controller [ATA]
- ATA Channel 0 (0)
- ATA Channel 1 (1)
- ATA Channel 2 (2)
-- Disk List ---------------------------------------------------------------
(1) Hitachi HTS541616J9SA00 : 160,0 GB [0/2/0, pd1]
(2) WDC WD30EFRX-68AX9N0 : 3000,5 GB [1/X/X, jm2] (V=152D, P=0551)
Model : Hitachi HTS541616J9SA00
Firmware : SB4OC70P
Serial Number : SB2404SJDAZ0HE
Disk Size : 160,0 GB (8,4/137,4/160,0)
Buffer Size : 7516 KB
Queue Depth : 32
# of Sectors : 312581808
Rotation Rate : Ukendt
Interface : Serial ATA
Major Version : ATA/ATAPI-7
Minor Version : ATA/ATAPI-7 T13 1532D version 1
Transfer Mode : SATA/150
Power On Hours : 14643 timer
Power On Count : 4013 gange
Temparature : 45 C (113 F)
Health Status : God
Features : S.M.A.R.T., APM, AAM, 48bit LBA, NCQ
APM Level : 4080h [ON]
AAM Level : 80FEh [OFF]
-- S.M.A.R.T. --------------------------------------------------------------
ID Cur Wor Thr RawValues(6) Attribute Name
01 100 100 _62 000000000000 Read Error Rate
02 100 100 _40 000000000000 Throughput Performance
03 118 118 _33 001A00000002 Spin-Up Time
04 _97 _97 __0 000000001514 Start/Stop Count
05 100 100 __5 000000000000 Reallocated Sectors Count
07 100 100 _67 000000000000 Seek Error Rate
08 100 100 _40 000000000000 Seek Time Performance
09 _67 _67 __0 000000003933 Power-On Hours
0A 100 100 _60 000000000000 Spin Retry Count
0C _98 _98 __0 000000000FAD Device Power Cycle Count
BF 100 100 __0 000000000000 G-Sense Error Rate
C0 100 100 __0 00000000008A Power-off Retract Count
C1 _84 _84 __0 00000002763B Load/Unload Cycle Count
C2 122 122 __0 00540008002D Temperature
C4 100 100 __0 000000000002 Reallocation Event Count
C5 100 100 __0 000000000000 Current Pending Sector Count
C6 100 100 __0 000000000000 Uncorrectable Sector Count
C7 200 253 __0 000000000000 UltraDMA CRC Error Count
DF 100 100 __0 000000000000 Load/Unload Retry Count
-- IDENTIFY_DEVICE ---------------------------------------------------------
0 1 2 3 4 5 6 7 8 9
000: 045A 3FFF C837 0010 0000 0000 003F 0000 0000 0000
010: 2020 2020 2020 5342 3234 3034 534A 4441 5A30 4845
020: 0003 3AB8 0004 5342 344F 4337 3050 4869 7461 6368
030: 6920 4854 5335 3431 3631 364A 3953 4130 3020 2020
040: 2020 2020 2020 2020 2020 2020 2020 8010 0000 0F00
050: 4000 0200 0200 0007 3FFF 0010 003F FC10 00FB 0110
060: FFFF 0FFF 0000 0007 0003 0078 0078 0078 0078 0000
070: 0000 0000 0000 0000 0000 001F 0702 0000 005E 0040
080: 00FC 001A 746B 7F69 6163 7469 3D49 6163 203F 0029
090: 0000 4080 FFFE 0000 80FE 0000 0000 0000 0000 0000
100: 9EB0 12A1 0000 0000 0000 0000 0000 8848 5000 CCA5
110: 25D3 13E4 0000 0000 0000 0000 0000 0000 0000 4000
120: 4000 0000 0000 0000 0000 0000 0000 0000 0009 000B
130: 0022 0000 0000 0000 0000 0000 0000 0000 0000 0000
140: 0000 0000 0000 0000 0000 0000 0000 0000 4001 0000
150: 8000 0000 344A 0000 0000 4225 2441 0000 0000 0000
160: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
170: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
180: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
190: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
200: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
210: 0000 0000 8000 0000 0000 0000 0000 0000 0000 0000
220: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
230: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
240: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 DFA5
-- SMART_READ_DATA ---------------------------------------------------------
+0 +1 +2 +3 +4 +5 +6 +7 +8 +9 +A +B +C +D +E +F
000: 10 00 01 0B 00 64 64 00 00 00 00 00 00 00 02 05
010: 00 64 64 00 00 00 00 00 00 00 03 07 00 76 76 02
020: 00 00 00 1A 00 00 04 12 00 61 61 14 15 00 00 00
030: 00 00 05 33 00 64 64 00 00 00 00 00 00 00 07 0B
040: 00 64 64 00 00 00 00 00 00 00 08 05 00 64 64 00
050: 00 00 00 00 00 00 09 12 00 43 43 33 39 00 00 00
060: 00 00 0A 13 00 64 64 00 00 00 00 00 00 00 0C 32
070: 00 62 62 AD 0F 00 00 00 00 00 BF 0A 00 64 64 00
080: 00 00 00 00 00 00 C0 32 00 64 64 8A 00 00 00 00
090: 00 00 C1 12 00 54 54 3B 76 02 00 00 00 00 C2 02
0A0: 00 7A 7A 2D 00 08 00 54 00 00 C4 32 00 64 64 02
0B0: 00 00 00 00 00 00 C5 22 00 64 64 00 00 00 00 00
0C0: 00 00 C6 08 00 64 64 00 00 00 00 00 00 00 C7 0A
0D0: 00 C8 FD 00 00 00 00 00 00 00 DF 0A 00 64 64 00
0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 00 00 85 02 01 5B
170: 03 00 01 00 02 53 00 00 00 00 00 00 00 00 00 00
180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
190: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0F
-- SMART_READ_THRESHOLD ----------------------------------------------------
000: 10 00 01 3E 00 00 00 00 00 00 00 00 00 00 02 28
010: 00 00 00 00 00 00 00 00 00 00 03 21 00 00 00 00
020: 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00 00
030: 00 00 05 05 00 00 00 00 00 00 00 00 00 00 07 43
040: 00 00 00 00 00 00 00 00 00 00 08 28 00 00 00 00
050: 00 00 00 00 00 00 09 00 00 00 00 00 00 00 00 00
060: 00 00 0A 3C 00 00 00 00 00 00 00 00 00 00 0C 00
070: 00 00 00 00 00 00 00 00 00 00 BF 00 00 00 00 00
080: 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00
090: 00 00 C1 00 00 00 00 00 00 00 00 00 00 00 C2 00
0A0: 00 00 00 00 00 00 00 00 00 00 C4 00 00 00 00 00
0B0: 00 00 00 00 00 00 C5 00 00 00 00 00 00 00 00 00
0C0: 00 00 C6 00 00 00 00 00 00 00 00 00 00 00 C7 00
0D0: 00 00 00 00 00 00 00 00 00 00 DF 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 89
Enclosure : WDC WD30 EFRX-68AX9N0 USB Device (V=152D, P=0551, jm2)
Model : WDC WD30EFRX-68AX9N0
Firmware : 80.00A80
Serial Number : WD-WMC1T0878854
Disk Size : 3000,5 GB (8,4/137,4/3000,5)
Buffer Size : Ukendt
Queue Depth : 32
# of Sectors : 5860533168
Interface : USB (Serial ATA)
Major Version : ACS-2
Minor Version : ----
Transfer Mode : SATA/600
Power On Hours : 117 timer
Power On Count : 19 gange
Temparature : 35 C (95 F)
Health Status : God
Features : S.M.A.R.T., 48bit LBA, NCQ
APM Level : ----
AAM Level : ----
01 100 253 _51 000000000000 Read Error Rate
03 176 176 _21 00000000180E Spin-Up Time
04 100 100 __0 000000000014 Start/Stop Count
05 200 200 140 000000000000 Reallocated Sectors Count
07 200 200 __0 000000000000 Seek Error Rate
09 100 100 __0 000000000075 Power-On Hours
0A 100 253 __0 000000000000 Spin Retry Count
0B 100 253 __0 000000000000 Recalibration Retries
0C 100 100 __0 000000000013 Device Power Cycle Count
C0 200 200 __0 000000000010 Power-off Retract Count
C1 200 200 __0 000000000003 Load/Unload Cycle Count
C2 115 112 __0 000000000023 Temperature
C4 200 200 __0 000000000000 Reallocation Event Count
C5 200 200 __0 000000000000 Current Pending Sector Count
C6 100 253 __0 000000000000 Uncorrectable Sector Count
C7 200 200 __0 000000000000 UltraDMA CRC Error Count
C8 100 253 __0 000000000000 Write Error Rate
0 1 2 3 4 5 6 7 8 9
000: 427A 3FFF C837 0010 0000 0000 003F 0000 0000 0000
010: 2020 2020 2057 442D 574D 4331 5430 3837 3838 3534
020: 0000 0000 0000 3830 2E30 3041 3830 5744 4320 5744
030: 3330 4546 5258 2D36 3841 5839 4E30 2020 2020 2020
040: 2020 2020 2020 2020 2020 2020 2020 8010 0000 2F00
050: 4001 0000 0000 0007 3FFF 0010 003F FC10 00FB 0100
070: 0000 0000 0000 0000 0000 001F 970E 0004 004C 0040
080: 03FE 0000 746B 7D61 4733 7469 BC41 4723 407F 00DC
090: 00DC 0000 FFFE 0000 0000 0008 0000 0000 86A0 0001
100: A3B0 5D50 0001 0000 0000 0000 6003 0000 5001 4EE6
110: 5834 7DA1 0000 0000 0000 0000 0000 0000 0000 401C
120: 401C 0000 0000 0000 0000 0000 0000 0000 0021 0400
130: 0001 0000 0000 0000 0000 0000 0000 0000 0000 0000
140: 0000 0000 0004 0000 0000 0000 0000 0000 0000 0000
150: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
200: 0000 0000 0000 0000 0000 0000 70BD 0000 0000 4000
210: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
220: 0000 0000 103E 0000 0000 0000 0000 0000 0000 0000
230: 0000 0000 0000 0000 0001 1000 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 46A5
000: 10 00 01 2F 00 64 FD 00 00 00 00 00 00 00 03 27
010: 00 B0 B0 0E 18 00 00 00 00 00 04 32 00 64 64 14
020: 00 00 00 00 00 00 05 33 00 C8 C8 00 00 00 00 00
030: 00 00 07 2E 00 C8 C8 00 00 00 00 00 00 00 09 32
040: 00 64 64 75 00 00 00 00 00 00 0A 32 00 64 FD 00
050: 00 00 00 00 00 00 0B 32 00 64 FD 00 00 00 00 00
060: 00 00 0C 32 00 64 64 13 00 00 00 00 00 00 C0 32
070: 00 C8 C8 10 00 00 00 00 00 00 C1 32 00 C8 C8 03
080: 00 00 00 00 00 00 C2 22 00 73 70 23 00 00 00 00
090: 00 00 C4 32 00 C8 C8 00 00 00 00 00 00 00 C5 32
0A0: 00 C8 C8 00 00 00 00 00 00 00 C6 30 00 64 FD 00
0B0: 00 00 00 00 00 00 C7 32 00 C8 C8 00 00 00 00 00
0C0: 00 00 C8 08 00 64 FD 00 00 00 00 00 00 00 00 00
0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 00 00 F4 A1 01 7B
170: 03 00 01 00 02 FF 05 A0 01 00 00 00 00 00 00 00
180: 00 00 01 06 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 61
000: 10 00 01 33 64 64 64 64 64 64 00 00 00 00 03 15
010: 00 00 00 00 00 00 00 00 00 00 04 00 00 00 00 00
020: 00 00 00 00 00 00 05 8C 00 00 00 00 00 00 00 00
030: 00 00 07 00 C8 C8 C8 C8 C8 C8 00 00 00 00 09 00
040: 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00
050: 00 00 00 00 00 00 0B 00 00 00 00 00 00 00 00 00
060: 00 00 0C 00 00 00 00 00 00 00 00 00 00 00 C0 00
070: 00 00 00 00 00 00 00 00 00 00 C1 00 00 00 00 00
080: 00 00 00 00 00 00 C2 00 00 00 00 00 00 00 00 00
090: 00 00 C4 00 00 00 00 00 00 00 00 00 00 00 C5 00
0A0: 00 00 00 00 00 00 00 00 00 00 C6 00 00 00 00 00
0B0: 00 00 00 00 00 00 C7 00 00 00 00 00 00 00 00 00
0C0: 00 00 C8 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B5
My second new hard drive (I have deleted the information about the system disk, as they appear above):
(2) WDC WD30EFRX-68AX9N0 : 3000,5 GB [1/X/X, jm1] (V=152D, P=0551)
Enclosure : WDC WD30 EFRX-68AX9N0 USB Device (V=152D, P=0551, jm1)
Firmware : 80.00A80
Serial Number : WD-WMC1T0901976
Queue Depth : 32
Power On Hours : 110 timer
Power On Count : 11 gange
Temparature : 28 C (82 F)
Health Status : God
APM Level : ----
AAM Level : ----
03 174 174 _21 00000000187A Spin-Up Time
04 100 100 __0 00000000000B Start/Stop Count
09 100 100 __0 00000000006E Power-On Hours
0C 100 100 __0 00000000000B Device Power Cycle Count
C0 200 200 __0 00000000000A Power-off Retract Count
C1 200 200 __0 000000000000 Load/Unload Cycle Count
C2 122 113 __0 00000000001C Temperature
0 1 2 3 4 5 6 7 8 9
010: 2020 2020 2057 442D 574D 4331 5430 3930 3139 3736
080: 03FE 0000 746B 7D61 4733 7469 BC41 4723 407F 00E0
090: 00E0 0000 FFFE 0000 0000 0008 0000 0000 86A0 0001
110: AD89 AD34 0000 0000 0000 0000 0000 0000 0000 401C
250: 0000 0000 0000 0000 0000 D9A5
010: 00 AE AE 7A 18 00 00 00 00 00 04 32 00 64 64 0B
040: 00 64 64 6E 00 00 00 00 00 00 0A 32 00 64 FD 00
060: 00 00 0C 32 00 64 64 0B 00 00 00 00 00 00 C0 32
070: 00 C8 C8 0A 00 00 00 00 00 00 C1 32 00 C8 C8 00
080: 00 00 00 00 00 00 C2 22 00 7A 71 1C 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 00 00 3C A5 01 7B
170: 03 00 01 00 02 FF 05 A8 01 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C5
I hope you will be able to help me understand if these disks are healthy and ready for deployment.
Thank you!
Xavis
- ATA Channel 0 (0)
- ATA Channel 1 (1)
- ATA Channel 0 (0)
- ATA Channel 1 (1)
- ATA Channel 2 (2)
Firmware : SB4OC70P
Queue Depth : 32
Health Status : God
0 1 2 3 4 5 6 7 8 9
Firmware : 80.00A80
Queue Depth : 32
Health Status : God
APM Level : ----
AAM Level : ----
0 1 2 3 4 5 6 7 8 9
Firmware : 80.00A80
Queue Depth : 32
Health Status : God
APM Level : ----
AAM Level : ----
0 1 2 3 4 5 6 7 8 9
Thank you!
Xavis
