So my computer stopped recognizing/reading my hard drives reliably and became unusable recently. At first I thought it was the HDDs/SATA controllers. But after testing the connectors on my PSU with a multimeter I found that while connected to the motherboard the PSU is outputting < 4.4v on the 5v wires. However if doing a paperclip test with just one hard drive connected I get 4.9v. The BIOS reports even less voltage than this. The other rails are fine.
I think this is the problem, but before I buy a new PSU, is there any possibility the PSU is not at fault? Is there any way the motherboard could be causing a healthy unit to output less voltage? Or is this a cut & dry faulty power supply unit?
Thanks.
This is a PC P&C Silencer 750w PSU, and an Asus P5B Deluxe motherboard by the way. The actual system uses not nearly that capacity.
Thanks.
