Uncore / QPI / Memroy help
Rossi~
Current setup and overclock is in my sig. Now, im thinking of changing the memory ratio to give 1863MHz, im pretty sure the memory can handle it, but that would mean the Uncore would be 3726 the same as the QPI. Would this cause issues? How high can the Uncore go?
Saying that Im not able to change the ratio to get 1863MHz unfortunately, there is 1654MHz then next up is over 2000MHz. Can anybody help me out here with the ratio's? Also anybody got any OCZ Gold 12800 overclocking experience? May just try and get 7,7,7,20 from it's current 8,8,8,24
The only way to get your ram at that speed is to lower your bclk to 183 and run the memory multiplier at 10. That is going to lower your oc to 3.7ish though too. I would personally try for tighter timings at 1600mhz. I've got gskills that will do 1600 7-7-7-17 at 1.63v but will not run at 2000 with any reasonable timings.
Ah yeah looks like that's gonna have to be it to get up to 18**MHz aye? Damnit.
Also just tried 7,7,7,24 1T and it's a no. It boots @ 1.76v DRAM and 1.475v QPI but BSOD when i run a blend in Prime95.
I don't think it would be worth it if i got it to work with more v's than that so gave up. Will probably work with 2T with a slight v increase but there would little point also.
I figured i have to upgrade to 6Gb RAM soon anyway so will look at 6Gb 2000MHz set's or jsut stick with a 6Gb kit of OCZ Gold and have 9Gb in total.
bum
