I have a question in doing a unattended install of Office 07 through GPO. I have modified the config.xml file accordingly and have tested it by the command prompt. I issued the following command to install Office 07:
C:\Office2007\setup.exe /config C:\Office2007\Enterpriser.WW\config.xml
This works perfectly and everything installs properly that I set in the config.xml file. How do I deploy this through a group policy now? I know for Software Installations you need a .msi file and from what I read I need to use the EnterpriserWW.msi file that is located in the same folder config.xml is located in. However, whenever I try to install Office 07 by double clicking the EnterpriserWW.msi file, I keep getting a error message saying: Error 1713. Setup cannot install one of the required products for Microsoft Office Enterprise 2007.
All the Office 07 files are located locally in my test VM and I have yet to move the Office 07 files to the file server.
