- Jan 28, 2004
Well, I just noticed when trying to upload a WU that it wasn't going. Checked the log file, and it seems like we've seen this before, where the server cannot find a record of this unit. I was hoping that one of you UberFolders with close ties to Stanford (are you reading this Evil
) might be able to pass the error on up and see if they can resolve it, before it hits many more of us folders out there.
Here is the log file...
Code:
Folding@Home Client Version 6.23
http://folding.stanford.edu
Launch directory: C:\GPU
Executable: C:\GPU\GPU.exe
Arguments: -send all
[20:55:35] - Ask before connecting: No
[20:55:35] - User name: Axdrenalin (Team 33)
[20:55:35] - User ID: 7AE3A2654309D9FA
[20:55:35] - Machine ID: 2
[20:55:35]
[20:55:35] Loaded queue successfully.
[20:55:35] Attempting to return result(s) to server...
[20:55:35] Project: 10502 (Run 12, Clone 0, Gen 42)
[20:55:35] - Read packet limit of 540015616... Set to 524286976.
[20:55:35] + Attempting to send results [May 17 20:55:35 UTC]
[20:58:11] - Couldn't send HTTP request to server
[20:58:11] + Could not connect to Work Server (results)
[20:58:11] (171.67.108.21:8080)
[20:58:11] + Retrying using alternative port
[20:58:32] - Couldn't send HTTP request to server
[20:58:32] + Could not connect to Work Server (results)
[20:58:32] (171.67.108.21:80)
[20:58:32] - Error: Could not transmit unit 00 (completed May 17) to work server.
[20:58:32] - Read packet limit of 540015616... Set to 524286976.
[20:58:32] + Attempting to send results [May 17 20:58:32 UTC]
[20:58:34] - Server does not have record of this unit. Will try again later.
[20:58:34] Could not transmit unit 00 to Collection server; keeping in queue.
[20:58:34] Project: 10502 (Run 12, Clone 0, Gen 42)
[20:58:34] - Read packet limit of 540015616... Set to 524286976.
[20:58:34] + Attempting to send results [May 17 20:58:34 UTC]
[20:58:55] - Couldn't send HTTP request to server
[20:58:55] + Could not connect to Work Server (results)
[20:58:55] (171.67.108.21:8080)
[20:58:55] + Retrying using alternative port
[20:59:16] - Couldn't send HTTP request to server
[20:59:16] + Could not connect to Work Server (results)
[20:59:16] (171.67.108.21:80)
[20:59:16] - Error: Could not transmit unit 00 (completed May 17) to work server.
[20:59:16] - Read packet limit of 540015616... Set to 524286976.
[20:59:16] + Attempting to send results [May 17 20:59:16 UTC]
[20:59:18] - Server does not have record of this unit. Will try again later.
[20:59:18] Could not transmit unit 00 to Collection server; keeping in queue.
[20:59:18] - Failed to send all units to server
Folding@Home Client Shutdown.
