awsiemieniec
- Jul 2, 2004
I have a client PC, Windows 7 x64 Pro, with IE9 installed. The user is unable to download files with IE9. As a test I installed another browser and was able to successfully download anything.
Things tried:
Sounds like something is wrong with the user's domain account but I'm hoping to fix this issue instead of deleting and re-setting up the profile.
Any ideas?
Things tried:
- Uninstall and reinstall IE9;
- verified download is enabled within IE adv settings;
- removed index.dat and had Windows rebuild it on reboot;
- emptied out temp Internet files;
- reset IE9 to factory defaults;
- disabled all add-ons in IE9 - no help;
- upgraded to IE10, downloading didn' work, downgraded back to IE9;
- User account is standard, but tested with elevating it to local admin with no luck;
- downloading with IE9 works with different domain account on same computer.
Any ideas?
