My old mobo used to have 4 IDE ports but my new one only has 2.
My new Asus mother board has an IDE cable that connects my 2 HDs on primary & secondry connector on one IDE cable.
My CDROM and DVD drives are connected up the same way, one cable onto the mobo with prim & sec connectors plugged into the devices.
I cannot get both the DVD & CDROM to work together. My mobo just cannot see them both, it will only detect one of them, the one on the primary connector (the secondry works ok as I've tested that & both devices can be detected individually and I can use them from my OS).
So all connectors work and all devices work when used individually.
I have tried flashing the BIOS & doing a manual scan within the BIOS to detect both devices on the same IDE cable but no luck.
I cannot detect them by searching for new hardware in windows and I cannot detect them in Linux.
Ive been stuck like this for a few months now and its really annoying having to open up my PC and switch the connectors between CDROM & DVD.
If anyone could help that would be great.
Thanks.
Thanks.
