unable to boot a xp machine
richb
Hi all
I need some help on a issue im having with a asus p4c800 mother board. the problem is-
it wont boot,no display, no error messages with monitor hooked up. i can hear the hard drive spin up then it sounds like it is loading something then it stops for some reason.
no error beeps, no audio . when the monitor is disconected i hear an audio message saying "system cpu failed test"????? and this just keeps repeading. i did reset the bios settings. when i hook the monitor back up, nothing no boot no display and no audio message. i dont know if its the cpu or the video card????????????????
im stuck can someone give me a start to where to start troubleshooting.
thanks
richb: confused:
You have been given a clue.
Try another CPU if its easy to borrow one.
If that doesnt fix it, let us know.
