videobruce
- Jan 21, 2005
Using two different wireless cards, I can't access the router with either. The current error message is;
Details:
Intersil SL2511CD EXT2 (WEP only)
Linksys WPC54GR (various choices)
Westell 327W DSL modem/router (WEP & WPA-PSK)
XP Pro sp2
HP ZV5000 Laptop using Carbus slot
I assume the registry got corrupted somehow. I orginally have been using the Intersil no name card since it has a external antenna. I then got the Linksys 'G' card. I removed the 1st card and installed the 2nd and tried to use one of the security protocols, but I couldn't get it to work. I turned off encription and it still wouldn't work.
Can I have drivers & software for two different cards installed in the Laptop at the same time?
I did removed the software of both cards and re-installed the Intersil S/W by itself. Where are the registry entries for this?
The only thing is I have security turned off in the router and the card.Data frame errors, check WEP settings
Details:
XP Pro sp2
