um..HELP?
Converge
Okay i dont know what the hell is going on. 30 minutes ago the power went out in my house, while my computer was on. I do have a surge protector...and my computer has shut down multiple times before due to the power going out. However, this time when i tried to turn on my comp, it didnt boot. Everything turns on, psu, fans, leds, etc. I just get a black screen though.
My specs are in my sig. On my motherboard, when i try to turn on the comp I get 3 out of the 4 red system condition leds go on. In the manual it says that 1 led means video is detected, 2 leds means rams detected, 3 leds mean cpu is detected, 4 leds mean system start up. WHY is my system not starting up??
I tried resetting the cmos but i got nothing. I tried setting the jumper to safe boot, but nothing happened.
HELP?
a surge protector will not stop everything, It can not do anything to stop a direct lightning strike, or even a really good voltage spike, It does help with the everyday surges you get however. They kinda give you a false sense of security. Power surges are very sneaky little buggers, they can go thru something that may seem very fragile and not harm them only to hurt something more robust. sometimes you can see burnt traces on your motherboard or Video card, other times you cant, only way to truely find out is to start swapping parts. I have seen in my experience that video cards seem to get hurt the most often from power surges so I would start with that if I were you, even if your onboard Diagnostics say it is detecting it doesn't mean its not defective.
sorry I cant be more help.
Not enough power can be just as damaging as too much power ..of which a surge protector will not protect you from "brown" outs ...that is why its good to get a battery backup ..even if just a cheapy 50 dollar one ..will help with your type of power problems.
