Ultramon & Vista
Tzzird
Do these two play nice together? I'm considering purchasing this program but I don't think there is official support for Vista. My brother uses it in XP and loves it.
I have Ultramon and it works great with Vista. I am currently using the beta 3.0 (3.0.2) with no problems. Its a great program.
Yup, like rscott said, works great. I also used the beta though, not sure about previous versions.
Im running the beta as well and it crashes every once in a while for me but its still a must have.
Agreed. Ultramon is a great product.
But there's a major flaw with the newer versions (3.0+). Normally, I could have dual monitors and a few RDC (Remote Desktop Connection) screens up. If you maximize the RDC, you will lose the Smart Taskbar (it'll go behind the RDC screen). In 2.7.1 and below, the Smart Taskbar will simple hide itself until you hover over it. The developer says he has it in mind to fix/add the feature for the next release.
Bummer. :(
