After reading the good reviews about the Ultra X-Finity, I decided to try it out with Outpost.com having it for $44.99 after rebates (not as good as Radio Shack deal). I got it and fired it up to hear a noise that sounds like a wire hitting a fan. When I shut it off, it made a sort of grinding noise. I got an advanced replacement from Ultra (nice service) and the replacement did the same thing, so I guess it is just the type of fan they use that makes these annoying noises. I decided to put the replacement into my computer and ran it over night. I noticed the pc monitoring alarm went off since the 5 volt rail hit 6.09 volts! I know software based readings may not always be accurate, but this had never happened with my 400-watt Fortron cheapie (system is Rig #2). Since I still had the original unit, I tried that. I had the computer on overnight, and the warning came up that the voltage was 4.32 volts WTF!? I decided to go get a cheapo 500-watt Antec smartpower 2.0 from CompUSA and have been running solid for 2 days without problems (so far). I had always questioned Ultra power supplies, but thought I would give them a try. I won't try them again. Tru though, I have had Fortron, Antec, PCP&C, TTGI, all start to fail, but not 2 of any not have good voltages right away. So now I am out money for shipping 3 times on this one. Nice. Oh well, it was my fault I guess. I hope other people have better luck with them. (Maybe they don't like ASUS A8R-MVP mobos)
