Ultra X-Blaster
atari52oo
Can I get thoughts on this case?
I am looking for a simple clean case that has good airflow and is somewhat quiet.
CPU/MB planned for this case:
Intel Core 2 Duo E6750 / ABIT IP35 - possibly OC'd
Thanks
looks like the inside layout was just thrown together, you got 2 3 1/2 bays up top, a couple seperate ones in the middle then the HD cage in the bottom. Doesn't look well planned out to me. However everything else looks good, 2x 120mm fans, nice clean looks. Dont know if its worth $100 or not, thats up to you, but it aint for me.
[edit] If you only have one or 2 hard drives, remove that lower HD cage to help clean up the airflow. You can either mount them up top of if you only have one in that spot below the 5 1/4 drive bays. or even in the 5 1/4 bays with adapters.
have you looked at the antec nine hundred? its got great cooling and its not that loud.. also you can try the antec p180
