Im not sure its supposed to be there in any non SLI pacages since in my pack it shows its there for U to be able to get to the jumpers between the SLI grapics cards... (Are there any jumpers there at all??)
It's also to remove the jumper block for using the 5v line for vdimm. If you have memory like OCZ VX that love to overvolt you need to move the jumpers on the corner of the board . This tool makes it easy. This is actually a chip removal tool so if you need to remove the BIOS chip you can use this.
