Ultra 600w PSU question....
Tech_Pro
yeah i'm going to get this psu but just one question, does it come pre sleeved? here is the link to it Ultra PSU .
THank you
if this is anything like the 500watt version.. stay away.. for 120.... ocz powerstream 520 or antec neopower > this 600watt thing...
DUDE. Get am OCZ Powerstream. You will not regret it. I got a 600 watter myself.
It is not sleeved. I would recommend a different psu also. That one has been shown to not have any heat sinks, or at least they were not visible. Enermax or ocz are good alternatives.
LKS
yes
a UV reactive modular wiring system presheilded and embedded in plastic with molded ends
its best feature in my opinion
(they can be a bit stiff for routing and obviously are of a set length, you cannot alter)
however, why you want it and what your trying to power would be very large considerations
its not a "high performance" supply, though many believe it to be
the queation becomes do you need or want a high performance PSU
Ice Czar said:
yes
a UV reactive modualr wiring system presheilded and embedded in plastic with molded ends
No, they do not come like that. If you look closely at the picture only the main ATX cable is sleeved black, the rest is not.
And yes, i would stay away from this version. Look toward an Antec or OCZ.
