access dual core? what do you mean. you're already got it and windows will recognize you have two cores, it just won't essentially optomize for your dual core. press Ctrl + alt + delete and click the processes tab. then choose any process that you're using and right click it. go to set afinity and you'll see 2 cores. That helps you assign a process to a certain core, makes everything a slight bit faster. (tip)
