well at least my luck with overclocking is consistent ...and by consistent I mean CRAP
i have
I5-2500K (w/ Hyper212+)
GA-Z68X-UD3-B3
4GB Mushkin Enhanced DDR3 1333
Samsung F3
XFX6870
HVR-1250
Corsair TX650W
so I thought I had my modest~ish 42 Turbo ratio oc all stable (43 43 42 42) vcore 1.300 LLC disabled ram timings set manually and standard selected instead of turbo for the ram.
anyways after 2~ hours prime 95 crapped out
i'm testing now having changed the voltages back to auto for vcore which has the temps
65 73 76 76 after about 1.5 hours now... i'm not super stoked on the temps over 75 but then again it is the hottest time of the year. I'm crossing my fingers that prime doesn't crash this time (time will tell I guess).
the reading I did makes it sound like 4.2Ghz should be a cake walk that everyone and their retarded monkey could achieve ...but of course as usual my luck with overclocking seems to be consistently shite
so on to the point(s)?
a. assuming that the auto (134V) proves able to run prime95+ without errors / otherwise is stable am i correct in assuming these temps would pose no great threat to my new toy in the near to mid / long term
b. am I doing something wrong most of the stuff I read suggests most can simply leave most the settings at auto and just crank the turbo ratio to 45 with success.
i have
GA-Z68X-UD3-B3
Samsung F3
XFX6870
HVR-1250
Corsair TX650W
