UD without a tray icon
1361
Is there a way to laod an UD set up with out a tray icon? I've never Borged (I think I'm using the right term) before and I just might give it a try.
If you look up in the faq
or go to www.hardfolding.com
there is information there on a program that is used to
run the command line as a service. FireDaemon is what
it is called. Really good for running it without a tray icon.
you can use EM3 as well.
www.em-dc.com
also functions as a monitor for your boxen (as in a way to check stuff)... UD has kickbutt monitoring though.
EM can't monitor UD...
But, using the HideItX program availabe in the download area, you can hide the UD icon without running it as a service. ;)
