I'm trying to configure a bridge network for VM's. I want the VM to share the physical adapter with the host, and I want both of them to get IP's from the router DHCP server.
I've got everything set-up based on the top answer from this link, except for some changes related to DHCP, as the answer assumes static IP's.
https://askubuntu.com/questions/1412503/setting-up-a-bridge-for-host-and-vm
contents of host-bridge.xml on Host
Contents of 50-cloud-init.yaml on Host
ifconfig -a on Host
(i see bro0 is listed here, this is a leftover from a failed previous attempt that included a typo, I'm not sure how to make it disappear, but as far as i can tell nothing uses this)
networkctl on Host
brctl show on Host
sudo virsh net-list --all on Host
and finally, the code from 'sudo virsh edit <myVMdomainName>' that is related to the network interface, related to the stack exhange answer/guide linked above
and for real finally, the output of ifconfig -a on my VM
Also, networkctl output on VM
Any help available here? I know this is a lot - and I'm definitely on a steep learning curve here.
In short, VM is not getting an IP. previously it was "working" with NAT - but that was just giving the VM internet access. I want full network access.
Code:
<network>
<name>host-bridge</name>
<uuid>89ae32dc-af81-4068-935d-f11aeabea5a9</uuid>
<forward mode='bridge'/>
<bridge name='br0'/>
</network>
Code:
network:
version: 2
ethernets:
enp3s0f0:
dhcp4: false
bridges:
br0:
dhcp4: yes
interfaces: [ enp3s0f0 ]
ifconfig -a on Host
Code:
br0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.143 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fdd1:93b8:5f1a:0:d438:1dff:fe31:c77 prefixlen 64 scopeid 0x0<global>
inet6 fe80::d438:1dff:fe31:c77 prefixlen 64 scopeid 0x20<link>
ether d6:38:1d:31:0c:77 txqueuelen 1000 (Ethernet)
RX packets 105054 bytes 16627847 (16.6 MB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 40977 bytes 56926588 (56.9 MB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
bro0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet6 fe80::6499:1fff:fe9a:f3de prefixlen 64 scopeid 0x20<link>
ether 66:99:1f:9a:f3:de txqueuelen 1000 (Ethernet)
RX packets 35012 bytes 3942046 (3.9 MB)
TX packets 27724 bytes 36671479 (36.6 MB)
enp3s0f0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
ether 44:1e:a1:55:7e:a4 txqueuelen 1000 (Ethernet)
RX packets 373442 bytes 205468683 (205.4 MB)
TX packets 265267 bytes 252462287 (252.4 MB)
enp3s0f1: flags=4098<BROADCAST,MULTICAST> mtu 1500
ether 44:1e:a1:55:7e:a6 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
enp4s0f0: flags=4098<BROADCAST,MULTICAST> mtu 1500
ether 44:1e:a1:55:7e:9c txqueuelen 1000 (Ethernet)
enp4s0f1: flags=4098<BROADCAST,MULTICAST> mtu 1500
ether 44:1e:a1:55:7e:9e txqueuelen 1000 (Ethernet)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 500 bytes 44445 (44.4 KB)
TX packets 500 bytes 44445 (44.4 KB)
virbr0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 192.168.122.1 netmask 255.255.255.0 broadcast 192.168.122.255
ether 52:54:00:13:d7:c6 txqueuelen 1000 (Ethernet)
TX errors 0 dropped 2 overruns 0 carrier 0 collisions 0
vnet1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::fc54:ff:fe97:8ae5 prefixlen 64 scopeid 0x20<link>
ether fe:54:00:97:8a:e5 txqueuelen 1000 (Ethernet)
RX packets 28927 bytes 2458997 (2.4 MB)
TX packets 82263 bytes 114661424 (114.6 MB)
networkctl on Host
Code:
IDX LINK TYPE OPERATIONAL SETUP
1 lo loopback carrier unmanaged
2 enp3s0f0 ether enslaved configured
3 enp3s0f1 ether off unmanaged
4 enp4s0f0 ether off unmanaged
5 enp4s0f1 ether off unmanaged
8 vnet1 ether carrier unmanaged
9 bro0 bridge no-carrier unmanaged
10 virbr0 bridge no-carrier unmanaged
11 br0 bridge routable configured
brctl show on Host
Code:
bridge name bridge id STP enabled interfaces
br0 8000.d6381d310c77 no enp3s0f0
bro0 8000.66991f9af3de no
virbr0 8000.52540013d7c6 yes
Code:
Name State Autostart Persistent
default active yes yes
host-bridge active yes yes
Code:
<interface type='bridge'>
<mac address='52:54:00:97:8a:e5'/>
<source bridge='br0'/>
<model type='virtio'/>
<address type='pci' domain='0x0000' bus='0x01' slot='0x00' function='0x0'/>
</interface>
Code:
enp1s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::5054:ff:fe97:8ae5 prefixlen 64 scopeid 0x20<link>
ether 52:54:00:97:8a:e5 txqueuelen 1000 (Ethernet)
RX packets 15 bytes 1050 (1.0 KB)
TX packets 894 bytes 292084 (292.0 KB)
RX packets 286448 bytes 20339712 (20.3 MB)
TX packets 286448 bytes 20339712 (20.3 MB)
Code:
2 enp1s0 ether degraded configuring
