ubnt UAP-AC-PRO / UAP-AC-Lite
Discussion in 'Networking & Security' started by jad0083, Oct 15, 2015.
  1. jad0083
    jad0083 Limp Gawd
    134
    Apr 30, 2006
    Anybody have these? Haven't seen much feedback elsewhere, and I can't find these in stock anywhere. Worth it to wait for these? or are there any good alternatives? Wait for wave 2 AC APs?
    In any case, looking right now for in-premise controller based AC WAP, for SMB that wont break the bank. Currently have 3 ubnt deployments (around 4-5 uap-pros each, managed by 1 central controller)
  2. trick0502
    trick0502 [H]ardness Supreme
    5,155
    Apr 17, 2006
    if you sign up for their beta forums you can get more info. as far as i know, they arent for sale yet.
  3. tangoseal
    tangoseal [H]ardness Supreme
    7,740
    Dec 18, 2010
    I have the UAP-AC in my house. The original one. It works fantastic. 24/7 no problems. Its a space heater though. I hope the eliminate the heat output on the pro series.
  4. jad0083
    jad0083 Limp Gawd
    134
    Apr 30, 2006
    yeah, I believe the first couple of batches were already sold out, so everything is on backorder. I remember seeing these on amazon before, but was reluctant at the time to try them out. Also currently looking at Aerohive and Open-Mesh, but I don't think these have in-premise controllers.
  5. dave99
    dave99 2[H]4U
    2,129
    Jan 20, 2011
    I have a couple of the uac-pros on order, no ship date yet though.
  6. bds1904
    bds1904 Gawd
    1,006
    Aug 10, 2011
    Not having an onsite controller is by no means a downside. I see it as a huge upside honestly. One of the huge downfall of the original ubnt ap's was the clunky controller that was required to set up the ap and required to run all the time for simple things to work (like walled garden & seamless roaming).
    I use open-mesh a lot, as well as at home. Open-mesh just works, period. I have 4 ap's at home and can roam between them on a VoIP or video call with no issues. The controller is great, easy to use and just advanced enough for all but the most complicated network setups. Bridging and bridge to vlan works great as does the guest network. I also like the usage graphs and L7 statistics you get.
    The OM5P-AN maxes out at about 60Mbps real world thruput to the internet and about 75Mbps on file transfers (On 5Ghz).
  7. klank
    klank Killer of Killer NIC Threadz
    2,145
    Aug 22, 2011
    I ordered two of the new pros and one of the lite. They will be here next Monday.
  8. Dawizman
    Dawizman Gawd
    830
    Jul 9, 2003
    We've had good luck with the original UAP-Pro, so I've got a few 5 packs of each the AC-Pro and Lite on order. Haven't read too much bad about them yet.
  9. trick0502
    5,155
    Apr 17, 2006
    From where?
  10. jpcolin
    jpcolin n00b
    48
    Mar 15, 2015
    have a look at the ubnt forum.
    I have read some things about those.
    First impressions are good from what i read.
  11. DouglasteR
    DouglasteR Limp Gawd
    453
    Jan 6, 2006
    My thoughts exactly. Also with the controller on my server, it updates automatically wich is very nice (not tinfoil hat proof though).
    Also it really get hot and consume about ~25w of my 48v POE Injector. Sometimes i think i can hear noises coming from it, like a eletronic whispering.
    It just works.
  12. BigTy
    BigTy Gawd
    943
    Feb 19, 2003
    Everything you just quoted was the knocks on the first gen AC's and you're not imagining the sound.
  13. Grentz
    Grentz [H]ard as it Gets
    17,118
    May 5, 2006
    Looking forward to them, I have had fantastic results with UBNT gear and have used all of the current gen APs (Unifi, LR, PRO, AC).
    They work great and kick the ass of any other gear in the price range. Coverage, reliable performance, etc.
  14. DouglasteR
    453
    Jan 6, 2006
    Really ? So it seems im not crazy..... yet :p
  15. jad0083
    jad0083 Limp Gawd
    134
    Apr 30, 2006
    Pulled the trigger on an AC-LR, let's see how that goes...
  16. trick0502
    5,155
    Apr 17, 2006
    from where?
  17. klank
    2,145
    Aug 22, 2011
  18. trick0502
    5,155
    Apr 17, 2006
  19. klank
    2,145
    Aug 22, 2011
    You can order one from just about any one of the distributors....
    Why don't you reach out to a few to see how long each one's back order is?
    Just because myself or another person is getting one or has them doesn't mean that you'd avoid a back order.
  20. +Eric
    +Eric Limp Gawd
    128
    Jul 4, 2012
    I have an UAP-AC-PRO. I ordered early from double radius, so I have mine already. Have had it for a few weeks now, has been completely stable so far.
    I think it's cheaper from A1 security though, although I know it's back ordered till December there as a friend has one on order with them.
  21. Sango
    Sango n00b
    39
    Feb 24, 2011
    Did guys order the US or World Version?
  22. klank
    2,145
    Aug 22, 2011
    They arrived...
    [​IMG]
    Damn these things are sleek and sexy. I believe I will be mounting them to the ceiling inside my house.
  23. Grentz
    17,118
    May 5, 2006
    Its been asked. But which distributor did you go through? My usual has yet to receive any and is forecasting dec.
  24. BigTy
    BigTy Gawd
    943
    Feb 19, 2003
    I found the lite, but can't find the LR :(.
  25. bman212121
    bman212121 [H]ard|Gawd
    1,533
    Aug 18, 2011
    Definitely want to see a mini write up on these. How is the range, the speeds, is it stable, etc. I've been waiting to see a review and am eagerly waiting to replace my AP with one of these.
  26. BigTy
    BigTy Gawd
    943
    Feb 19, 2003
    Doubleradius has a bunch now :).
  27. trick0502
    5,155
    Apr 17, 2006
    ive seen the lites and lrs, but i want the pro. i cant find that anywhere. from what im hearing you wont be able to get it till mid dec.
  28. scobar
    scobar .
    34,066
    Jan 2, 2001
    Might need to check these out once the demand simmers down, and a few firmwares have been issued, you guys go ahead, we always need a burn victim :)
  29. klank
    2,145
    Aug 22, 2011
    I haven't had a lot of time to write up a review, but I did find this...
    http://arstechnica.com/gadgets/2015...-realize-how-terrible-consumer-wi-fi-gear-is/
    As for using the two AP Pro's in my house, I haven't experienced any problems. I have not done any IPERF tests or file transfers from my surface pro 3 or mac book. If I get some time I will do some IPERF testing. Haven't fired up the AC-Lite yet, it is on my to-do list.
  30. ltickett
    ltickett [H]ard|Gawd
    1,125
    Jul 27, 2000
    graphs look rather disappointing performance wise when compared to an old airport extreme?
    i have to admit i've been somewhat disappointed since moving from my airport extreme to UniFi AP-AC v2
  31. scobar
    scobar .
    34,066
    Jan 2, 2001
    Take a peek at your wifi card settings, and see if you can tweak it a bit once. Here I did some tweaking and was able to double my throughput.
  32. bman212121
    1,533
    Aug 18, 2011
    If you're using a MBP connection to an airport extreme then it probably can seek out a little more performance as the two were likely tuned specifically for each other. I wouldn't put much faith in that synthetic number at all as it seems overly optimistic for what a perfect connection would even achieve. (You would need to have less than 35% overhead)
    If the same test was ran with a pc it's hard to say if the results would put them closer or not. I'm reserving my judgment until we can get a non perfect scenario test to see how well they can hold on once you are not on top of the AP.
  33. trick0502
    5,155
    Apr 17, 2006
    seeing how it is a 1300mbps ap (on 5ghz band), wouldnt 650mbps really be the max you would see? so, 500mbps sustained is about what is expected.
  34. travanx
    travanx [H]ard|Gawd
    1,577
    Apr 9, 2000
    These were showing up on Amazon for a large markup over the weekend. But not sure if these are the world or US version. The one showing up on ebay says world and not to be used in the US. Been really happy with the egderouter so I am waiting to get a couple of these.
    How hard is it to create a wireless bridge with these? I want to run one of these bridged in my garage.
  35. tonyyy
    tonyyy Limp Gawd
    306
    Nov 10, 2009
    got mines so far the speed improvement is awesome however I do have one issue with one of my laptops won't reconnect to the wifi after it goes to sleep. I have to power cycle the ap in order to reconnect. supposedly they have an beta firmware out there to resolve 2.4ghz issues... but you need to manually install it to fix it... i hope they get a final version of it out soon.
  36. bman212121
    1,533
    Aug 18, 2011
    It's a bit low, but not terrible. I generally figure you can get around 60% of the theoretical bandwidth. So 1300 x 60% is around 780mbps. That's if you're sitting right on top of the AP as it's usually difficult to keep Short Guard enabled so drop down to around 700mbps. I would expect in an ideal case you should be able to get a 700mbps transfer out of it. In normal usage though I would say getting 500mbps through a wall or two or lower signal would be a good result.
    @tonyyy: I hope they can get that stuff sorted. Seems like maybe they are trying to rush these out again as they had issues with the first AC APs when they came out.
  37. klank
    2,145
    Aug 22, 2011
    I don't have this issue with the AC-Pro or AC-Lites. Which model did you get?
  38. tonyyy
    tonyyy Limp Gawd
    306
    Nov 10, 2009
    AC lite.
    It seems to be isolated with anything on 2.4ghz... been reading a lot on ubnt forums.
    I'll just keep rebooting for now and hope a support updated firmware gets release soon as I don't want to hose my brand new AP's :(
  39. klank
    2,145
    Aug 22, 2011
    I did some basic iPerf 3 testing:
    Client/Server Specs
    Desktop1 (SSD, Gigabit Ethernet)
    Desktop2 (SSD, Gigabit Ethernet)
    Macbook Pro Mid-2009 (SSD, 802.11n)
    Surface Pro 3 (SSD, 802.11ac)
    Samsung Galaxy Note 5 (802.11ac)
    Unifi-AC-Pro 5Ghz WPA2-AES Channel Width HT40 Transmit
    Desktop 1 <--> Desktop 2 = 939Mbits/sec
    Desktop 1 <--> Note 5 = 168Mbits/sec
    Desktop 1 <--> MBP = 128Mbits/sec
    Desktop 1 <--> SurPro3 = 123Mbits/sec
    Unifi-AC-Pro 5Ghz WPA2-AES Channel Width HT80 Transmit
    Desktop 1 <--> Desktop 2 = 942Mbits/sec
    Desktop 1 <--> Note 5 = 242Mbits/sec
    Desktop 1 <--> MBP = 188Mbits/sec
    Desktop 1 <--> SurPro3 = 190Mbits/sec
    So far pretty weak. I will need to turn them off and fire up a Nighthawk, AC-Lite, Cisco 1252 and compare tomorrow.
  40. bleomycin
    bleomycin Limp Gawd
    236
    Aug 14, 2010
    Wow, thanks for posting that. Truly pathetic results though :eek:
    I don't understand why ubiquiti can't put out hardware that isn't crippled in some way. My 3 original ubiquiti uap-ac's are rotting in a closet now for similar terrible performance reasons.
