Zarathustra[H]
Extremely [H]
- Oct 29, 2000
Hey,
Has anyone used Ubiquiti's edge routers in general, or specifically their 5 port POE model?
For a long time I have used pfSense on my ESXi box as my firewall and router (with a passed through WAN Ethernet adapter, to minimize security implications).
While I really like pfSense, lately, this has really become an annoyance. Every time I need to take the server down for maintenance, my internet goes down as well, making it more difficult to download patches, look up guides, go on forums for questions, etc. when I am in the middle of my projects.
I have considered building a dedicated pfSense box using spare hardware I have kicking around, but I feel like even with the low power stuff I have, this would be a significant step up in power use, which I am trying to avoid.
I'd also hate to move back down to consumer hardware.
Because of this, and because of my appreciation of enterprise networking hardware, I have started thinking about getting a dedicated edge router. Because I already use - and am very happy with - Ubiquiti Unifi products for my WiFi, and they tend to be reasonably priced, they were the first ones I looked at.
If I was going to go with a Unifi router, I figured I might as well go with one that has PoE so I can power my current Unifi AP from it, declutter a little bit by getting rid of the PoE adapter, and hopefully save a little power, by having them powered from the same source. If I was going to go with PoE also wanted to have at least one PoE port open for future expansion, which is why I started looking at the ERPoe-5, which is fairly reasonable at ~$150
Does anyone have any experience with these? It seems like they might integrate nicely with the Unifi controller software, and I've been very impressed with the only other products of theirs I've used thus far, so if it is any indication of how their edge routers perform, I'm sure I'd be happy with them as well?
Any comments regarding these?
Are there any other reasonably priced dedicated routers I should be looking at? (they don't have to have PoE)
I'd appreciate any thoughts on this subject matter. One thing I've found to be kind of tricky with pfSense is to get traffic shaping set up the way I like it. The queues and firewall rules get a little complex and confusing. If there is any product that simplifies this process, it would be a big plus.
--Matt
--Matt
