NoEcho
- Aug 14, 2001
Was just checking out some heatsinks on newegg.
I don't need any heatsinks, but still floats my boat to look at them.
I noticed some pretty nice, new ones from Asus. Copper base. Heat pipes. Shiny blue plastic fan. Also noticed that the copper fins appear to clip into the copper base. Copper is notoriously hard to do tight work on (like grinding out fins) and think it solders poorly too (conveys the heat too well) so you typically end up with fins that are making only partial contact with their copper base.
I wonder if anyone has ever done a good comparison of similiarly designed, simliarly weighted heatsinks - one each - of clip on copper fins and contiguously molded aluminum.
