u320 ok for OCing?
typhoon43
Just wondering if SCSI setups are more particular about OCing than SATA/IDE. If I did a U320 card and 15k drive, would I hinder my overclockability? I assume I can lock the PCI/AGP divider , but is there anything else I should look out for?
Thanks.
If you can lock the pci divider there shouldn't be any problems.
also check power requirements during spin-up and heat output.
the newer cheetahs don't run as hot as the originals, but they will still warm up your case a bit, if you don't have good airflow.
