U3014, Mobility 4670, Displayport = FAIL
Sovereign
The only way to get 2560x1600 out of an XPS 1640 is to use DisplayPort since the HDMI port is limited to 1080p.
Fine.
Problem is, it doesn't work. I always get "Link failure detected" when the display connects to the computer. I'm using the DisplayPort cable that came with the monitor (Dell-branded).
Here's where it gets interesting: If I reboot the laptop with the monitor attached, the Windows boot sequence shows up on the U3014! As soon as Windows finishes booting though, back to black.
Any ideas?
Doesn't work. PowerStrip and Windows report the maximum resolution is still 1920x1200. Thanks though.
