typical- is my psu enough?
badbadtz560
seasonic s12 - 380watt
on a system w/:
asus p5b
some c2d . . probably e6300 or one of the newer series like e4300
2x1gb ram
ati x850xt
audigy 2 zs plat
tv tuner of some kind (ati elite?)
raptor 74gb
wd se16 320gb hd
dvd burner
Just curious if you guys think this psu will be enough. If not, How much power do i need? I'm not going to upgrade it more than this so I don't need futureproofing on it
It'll be fine however as great as the output is of the seasonic, you may want to upgrade if your shooting for a G80..otherwise your fine.
It's fine, you don't have to worry. Actually it's more than just fine - that Seasonic S12 380W is really great PSU, one of the best you could get, powerful and stable, plus it's very quiet.
