Tyan Tomcat K8S (S940)
Gillette
I'm building a low-end server system with this box and I'm having some trouble.
Specs:
Tyan Tomcat K8S
Opteron 144
1GB Crucial (Micron) PC-3200 ECC, Reg (Single DIMM)
Unknown HDs (2 80GB and something else, all PATA, 2 80s on a RAID-1 controller)
Promise Tech IDE RAID controller
ZNYX Networks 4port 10/100 NIC
OCZ Powerstream 420W PSU
On powerup I get a repeating beep, obviously a POST error. This is accompanied by no video output from the onboard video. I referenced this POST error to the manual and it says it is a RAM problem. I was doing some reading and apparently if the CPU is set to use 128bit bus I need at least 2 DIMMs.
Can anyone confirm that this is the problem before I waste time/money on the phone with AMD/Tyan/Crucial?
I think it should work with one dimm, but just in single channel (64bit) mode.
Reset the BIOS (clear CMOS jumper) remove everything not needed to boot, and reseat the RAM and CPU/Heatsink first. (try different DIMM slots too)
==>Lazn
Reset the CMOS, removed everything non vital... same problem.
Is it actually possible to mix-and-match RAM speeds with ECC/Reg RAM? I've never had to deal with this stuff before...
