I have some corsair pc3200 reg/ecc low latency that I used on my iwill dk8x, and it is giving me problems on the tyan k8sd pro (for the record, I never had any problems with it on the iwill). When I have two dimms per processor I get a bios error saying that there was a memory r/w error, and if I try to install linux or run memtest the computer reboots almost instantly. However, if I have 2 dimms on one proc and 1 dimm on the other it appears to be ok. Also, if I have all 4 dimms on one proc it appears to be ok. There are a couple more configs I would like to try, but I have tried other memory sockets (ie I used the 2 closest to the proc and then the 2 furthest from the proc). It had an old bios (march 05) which was not even listed on the website. I updated the bios and still got the same problems. I tried with and without ecc chipkill and it makes no difference. I also tried chaning the pairing and it made no difference. Any ideas? I am getting some more memory in a few days so I will see if it is just the board not liking my memory.
Ok, here is the new info. It has issues with running in 128bit mode on the second processor. I am now running memtest with the dimms installed in slots 1 and 3 for each proc and it looks like it is fine. Now comes the hard part, what is causing the problem (the ram, the mobo, the cpu(s))? I will be getting another one soon so I should be able to try it out.
