Tyan S2466N-4M
interquad
Does anybody out there know if a Tyan S2466N-4M will work with non-ecc memory? I ordered 2x512 sticks of non-ecc memory so I'm hoping it will. I've checked the manual and it just says registered.. but on google a lot of them are saying unregistered... So does anybody out there have any ideas for me?
Teh board will work with up to 2 sticks of unregistered memory installed. If you want more than 2 sticks you must use registered memory(all sticks)- ECC is optional either way
will work, i have one. MPx chipset unofficially supports 2x non registered modules. I had stability issues with non ECC though.
