Tyan RAID fresh install failure
mlistman
Trying to set up a new server with Windows 2003 using a Tyan Tomcat i7210 S5112 motherboard with a pair of 74gb WD SATA hard drives. Using the bios and RAID configuration I've set things up as best as I could (RAID is recognized during POST with no errors and it is set as bootable in the utility) During OS install I successfully load the third party (Silicon Image Sil3114 SATA) RAID driver and continue. When reaching the disk prep portion of the Windows install it says that there are no drives available.
The install works fine if I don't set up the RAID, but of course that's not what I want. I'm confident that the individual components are working properly and that this is a configuration issue.
Any suggestions?
