TYAN K28W model 2875
lifesuck
Dear All:
I just updated the bios from tyan version 2875-205 , and everything went south after updating it.
It showed the new bios version but I could not be able to create sata raid , it did not gave me any option to cread SATA raid, anyhelp would reall appreciate it.
Thank you very much for all the helps and suggestion
Tyan Tiger K28W Model 2875
dual AMD Optoron 240 processor
4 Western Raptor sata 40gb 10000rpm
1 Western 250gb
2GB mushkin memory ram
Plextor PX-716A
Aopen multi dvd/cd-r
Regards,
Hung Tran :confused:
Check to make sure your board has SATA RAID capabilites. Make sure the SATA controller is enabled in the BIOS. Then, reboot and go through the boot-up. Some boards have a prompt after the POST to go in and configure RAID. If that doesn't help, I would try talking to Tyan.
