Hey guys,
Here is the situation. I have the above mentioned router in my brother's bedroom, my computer uses the Edimax EW-7128g with a 5Dbi external antenna, there is about 100 ft and 2 walls (non-brick) between us. The wireless Tx rate constantly drops to 5-5.5Mbps no matter the settings, channel, etc... There are a lot of wireless networks in my area, but even channel 1 which is pretty much unused will yield the same result. If I go in and change settings in the router the rate will increase for a while, then it will drop again. At this point I am not sure what to do: either buy a better router, looking at a Buffalo, or a Netgear N, or just drill a hole through the wall to connect a Cat5 to the router.
Any suggestions? Thanks in advance.
