Two wire fan leads?
mwin
I swapped the 80mm fans in my X-Connect with Nexus true silent ones. The fans that were in there had two wire fan leads. They had a little plastic connector that hooked them up to the power supply. I cut the leads of one of the existing fans and spliced it onto the lead from my new fan. But I messed up the other one. Does anybody make these little two wire fan leads? Tonight I'll try to get a picture of one to let y'all know what I'm talking about, if you don't know already.
Same as the 2pin connectors on low range Nvidia cards yeah?
I dunno, to be honest. Never had a low-end nVidia card ;) .
I think I found some on Performance-PCs.com
