Two video cards causing my PC to crash?
I obtained another monitor for my desk because I thought it would look cool...so I went out and bought a PCI video card (nVidia 5500 PCI) to go with my 6800 Ultra AGP. Now these two won't boot together! I've tried running with the AGP first and then enabling the PCI but then I get the blue screen of death and then reboots. Both work independently though. Am I out of power? I have an Antec 520W PSU so I don't see any reason for a power outage (unless it's the AMD64 chip). HELP!!!
The system also have two HDD inside coolers, a floppy, a 250 zip drive, and a CDR\DVDRW combo.
Just another quick thought...is it because of the sheer desktop real estate that is causing the video cards to crash? The main monitor is a 23" and then there are also two 19", making it a total of 4480x1200 desktop.
so wait....you have two monitors hooked up to your 6800 ultra, and one hooked up to your 5500 pci?? I really do not think that a PCI and AGP card can work together in the same system...Stick with one video card.
As far as I know, it should just work. PCI and AGP videocards work just fine together (except for some older (< 4 MB) PCI cards. Both cards are nVidia, which is also good (ATi and nVidia seldom play nice together).
What are the total system specs?
Athlon64 3400+, 2GB DDR400, and the above mentioned components. The only problem I can think of is that the 6800 is from Asus and the 5500 is from MadDawg(?). I've done a AGP and PCI combo before, but not something that is power hungry or huge (desktop size) before. It was only 1024x768x3 with three Voodoos.
And what is the mainboard? :)
See if you can find another PCI videocard to test with.
