Two Raptors in an Array
ok, i just did this last night for the first time too... so when your computer boots up, press f10 when it says to enter nvraid feature. when it loads, create a new array, move both drives you want to use to the right side, and choose stripe mode. select stripe size (i went with 128k), save the changes and restart. and there you go, you have it. if you want to install windows on this drive, you have to press f6 to load the raid drivers when installing.
