NeghVar
- May 1, 2003
I have 2 x LSI Logic L3 25121-61A controllers cards. Is it possible for identical RAID controllers to work together to support a single array?
They are 4-port controllersFor what purpose? I don't think it's technically supported, unless you layered software RAID on top of the hardware RAID. Why not run all 6 on one controller?
Yep, that's right. The controller software would have to support it since you could, for example, run RAID 1 with 1 drive on each controller.I think the term you may seek is Duplexing.
Did some reading on the and yes, that is the answer I am looking for.
http://www.pcguide.com/ref/hdd/perf/raid/concepts/genDuplexing-c.html
