Two quick WC questions - buying soon
Appa
Ok here it goes, I'll keep it short and simple. I did a search and could not find an answer, so don't yell at me!!!! =P
Question # 1: What's the BEST block for socket 775 (this will cool my QX6700 while overclocked)? This thing throws a lot of heat....
Question #2: Do I have to use the same ID tubing for ALL items in the loop? What I mean is, does my entire setup need to be 1/4" or 3/8"...etc.
Question #3: What are the BEST types of fittings to use? The metal twist clamps? or plastic push on with straps on the outside, etc.
Thanks!!
1) swiftech storm
2) yes... use 7/16" ID tubing
3) DD metal ones, use 1/2" fittings with 7/16" tubing and you don't need clamps. heat the tubing up in warm water or with a blow dryer and put it on, when it cools it will not come off.. :)
You ROCK! Thank you very much. :) :) Adding to cart now. hehehe
btw that swiftech storm is like...out of stock everywhere I look! :(
