Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Can we PM the [H] folders that are no longer producing just to give a little nudge or ask if they need a part or something? Question #2 is should I be doing these larger WU's I'm hearing about with my machine? They give more points or something?
On the second question, go for the big WUs. You can enable them by right-clicking in the F@H display and clicking on configure. Then, go to the connection tab and the last option at the bottom is the option for allowing/disallowing big packets. Put a check in that box and click ok. Then you are good to go; these instructions only work with the graphical F@H client. I do not know anything about the other version of F@H. A note on big packets: enable them only if your rig has more than 256mb RAM.
Setting phaser to "big WUs", thanks. Yeah I guess it could be considered spam. There are just so many that I'm passin' by, its like a mass grave! I'd be willing to bet a lot of those guys have just reinstalled and forgot to put it back on.
