Two Questions
Labmouse
Motherboard: ASUS A7N8X-X, bios rev 1010.
Ram: Kingston KVR400X64C3A/512 x 2.
CPU: Athlon 3200+ (xp? don't remember).
Questions:
1. When utilizing one stick of the kingston memory, there are no issues. If I put both in, the computer randomly reboots when usage reaches approximately 250-300mb. No amount of swapping them around in the various slots has any effect. Any suggestions regarding the resolution of this problem?
2. Minor Q, how does one turn on dual channel support in the mobo, it always says 'single channel mode' at the bios screen.
Thanks for your time and any answers.
1- have you tried different ram? What is the ram settings in bios?
2- You enable Dual channel by putting the ram in the correct ram slots. On my old machine (A7N8X-E) I had to put ram in slot 1 and 3 for dual channel.
Have you tried putting in the RAM, and running Memtest? My stepdad had a set of kingston RAM that gave him no end of trouble...turned out that one of the sticks was just bad. RMAed it back to the manufacturer, and the new stuff works perfectly.
