Two questions (LCD and Router)
Kev
Question 1:
My girl friend has a 17" LCD. It's getting near the end of the seimster and we were wondering the best way to transport it? We were considering just putting a blanket over it and calling it a day. The box is who know's where. Is that a ok way to transport it, or what do all of you suggest?
Question 2:
I am thinking of picking up a Router. I can get one at school: Netgear 802.11B Wireless Cable DSL Router w/ 4-Port Switch for $57.28 . The write up is: When you connect your cable/DSL modem to the Netgear Wireless Router, you'll enjoy wired or wireless Internet access for all your computers and be assured of protected communications on your home or small office network! This 3-in-1 Router + Switch + Wireless Access Point is a base station that allows you to share your Internet connection, files and printers with other computers on the network. Your communications and network are secure from hackers and wireless eavesdroppers because they're shielded with Network Address Translation (NAT) Firewall. Internet activities are always safe because Web-address filtering gives you control over any contact network users have with Web sites. Not only that, there's also a free, full-version of Freedom Personal Firewall software included (for 8-PCs, a $240 value) to block ads, manage your passwords, and prevent applications from sending your personal information over the Internet. Works with PCs, Macintosh, and virtually all Ethernet devices, and comes with a free network cable and vertical stand to save desk space.
Is this a good deal or should I look around for something else?
I also found this one. Linksys EtherFast Wireless AP + Cable/DSL Router w/ 4-Port $62.76. Are either of these good deals or should I keep looking? I am looking to connect a Win 98 box and 2-3 XP laptops and eventully a XP Box.
I tape bubblewrap around my LCDs whenever I have to move them. I tape it tight around the frame, so nothing touches the LCD surface, and then another layer or two around it.
I'm not a big fan of Netgear stuff. Check the prices at your local store for Linksys stuff. The price isn't bad though.
Thanks for the advice. Did the second router I posted look ok?
I kept the boxes for my two 1800 fp's. I wanted to be 100% sure they'd make it ok. You are looking for a way of transporting them without having anything touching the screen obviously and the way they came is with styrofoam around the whole thing but raised away from the screen area....
if you put a blanket over it and call it a day just make sure it lays face up and that nothing touches the screen. You should be ok as long as you are careful...
that linksys will serve you well. Is that the version with built-in firewall?
Just remember, be SURE to change your default router password;)
-EtherFast Wireless AP + Cable/DSL Router w/ 4-Port Switch provides the ideal solution for connecting your wireless network to a high-speed broadband Internet connection and a 10/100 Fast Ethernet backbone. Configurable as a DHCP server an existing network, the EtherFast Wireless AP + Cable/DSL Router acts as the only externally recognized Internet gateway on your local area network (LAN) and serve as an Internet NAT firewall against unwanted outside intruders. The Router can also be configured to filter internal users access to the Internet. The device supports the 802.11b wireless standard and offers 4 10/100 Ethernet ports.
