two pumps questions
mateo
I was wonder what you guys thought would be better for flow:
pump > 360 rad > 360 rad > another pump > gpu
or using the EK dual pump modification and do:
pump + pump > 360 rad > 360 rad
or do you think just one pump would be sufficient
for a loop with res/two 360 rads/1 gpu block/cpu/northbridge block
the pumps are Swiftech MCR320-QP
thanks for any advice
what pump/s are you using again? the part number you listed is for a radiator.
In most cases, one pump should be fine, I have the stackable radiator 2x 320's setup from swiftech running through 2x ek vid blocks going though a mcp355 with a xspc res top without any problems.
sorry pump is a the mcp355 as well and it will be running through the switftech stackable rads too. So you dont have a problem with flow? do you have a res?
no problems with flow at all, I use the xspc res top in leiu of a seperate res, it improves performance of the pump as an added bonus as well.
One pump should suffice. Having too is a nice fail safe though. I have seen threads where a pump will fail and block tops will actually melt. Sounds like you've got a nice setup there, though.
