Hi,
I'm building a new system, i'm waiting to see the new DX10 cards from ATI to make the best choice between them and NVIDIA... Anyway getting to the point! From what i've heard those new card will be power hungry... a lot!!! So i was wondering what should i do, get a really powerful one to drive a full system with a Crossfire/SLI, or get a "normal" one and those new 5.25inch drive bay power supply from Thermaltake http://www.thermaltake.com/product/Power/PurePower/w0130/w0130.asp , one per card. The reason why i'm asking is i want it to be as cool as possible, and was wondering if a normal power supply with two small would create less heat than a big one?
Also, i'll probably go with the Silverstone TH07 Case, which can accept 2 power supply, how can i plug two power supply in it( i guess i wont plug them both on the mobo, but the second ones needs to power up with the system also..). And will it need two power cables outside the case or only one will provide them both? Is this worth doing(with what is mention above)? This part confuse me...
Thanks!
Thanks!
