two part os question
whatsup everyone anyways...i got two problems that i need resolved and i dont know how about going to do it.
Q1. I want to reformat my laptop that has XP pro. I have never reformatted before. I have the cd for it and all the driver cds. So how do I go about reformatting it?
Q2. I have another laptop thats running vista and I can't stand it and I want to put XP pro on that machine as well. How would I go about reformatting that and installing XP?
thanks
Just put in your XP CD and reboot the computer. The installation process gives you the option to reformat the hard drive. It's pretty straightforward.
Putting XP on the other machine would be illegal. You would not be able to do it with the CDs you have, either.
thanks
1. Just boot the Xp cd and follow the on screen instructions.. You may have to set your bios to boot from cd.. Also, I recommend you download the latest drivers for your hardware from the web, export your bookmarks, and save your current theme, then burn them to a cd.. http://www.winsupersite.com/showcase/windowsxp_sg.asp and http://windows.radified.com/ are where a couple of install guides can be found..
2. Same as 1, but you have to buy another copy of Xp.. Can't use the same key on both machines at the same time, it would violate the eula, and cause you activation headaches..
yea thanks...i knew i would have to buy a new XP disc. Im glad we sell that at my work so atleast I can get a discount. So for the Vista machine would it be easy as just putting the new XP disc in and following the instructions?
Yup!
You'll probably want to find the XP drivers for your video and network cards (if they're not built-in) and have them on hand on a CD or flash drive before you start the installation. It can be frustrating trying to search online for drivers when stuck at 800x600 or not even being able to get online because you don't have the drivers for your motherboard's built-in ethernet controller.
I've seen people have problems removing Vista and reverting back to XP on the same disk, in terms of formatting. I'd download something like GParted, and clear the drive completely before starting the XP install, just to be sure.
