Two Options in my Dell package. Please Help
Jelyrol
I'm getting a 5150 pc package as a gift in a few days and there is basicly only 3 video card options.
INCUDED IN THE PRICE:
128MB PCI Express™ x16 (DVI/VGA/TV-out) ATI Radeon X300 SE HyperMemory
+$50 for:
256MB PCI Express™ x16 (DVI/VGA/TV-out) ATI Radeon X600 SE HyperMemory
or
256MB nVidia Geforce 7300LE TurboCache
I'll be upgrading to wither of those two for $50... or is it even worth it? lol
ok, if you had to pick one which would it be? I can;t seen to find any stats on their products so i haveno clue lol
hi,
if u plan to upgrade to 256mb radeon..i have one right now in my dimension e510 that i need to get rid in order for a new graphics card. they are okay if u play games.. i was able to play fear on a minimum settings ..fable , pro evolution soccer works well with this one..and sims and the movies game..they are awesome..just gimme a pm.
i'd say get whatever and then save up for a good video card. Maybe a 7800gt/7900gt or an x1800xt/x1900xt or something. You won't be able to play any graphics intensive games with those vid card options with the dell on anything but low settings. Save up, trust me, its worth it for a good video card if you play games.
Don't waste your money on Dell's crap.
Take the free video card and order an eVGA 7600GT for $146 after rebate.
As soon as your Dell arrives, take out the x1300SE and sell it on ebay. Then install the 7600GT.
For about $120 net, you'll have a FAR better card.
Installing/removing the video card is cake BTW. Just remove a screw (or lift a green tab) and pull the card out/push it in.
how much do u think the 256mb radeonx600 and a 300W Dell power supply worth on ebay?
i plan to get rid of them
That all sound nice but I didn't get an answer.. im not a gamer nor do i want to buy another card. the +50 is canadian $ btw..
of those two cards whats the better choice?
How much RAM are you going to have?
ATi HyperMemory and nVidia TurboCache use system memory instead of dedicated video memory.
HyperMemory™ is ATI’s innovative technology that enables a reduction in the amount of on-board memory on a graphics card without compromising its overall performance.
Its advanced memory management technology makes more efficient use of all the available memory in computers with PCI Express® technology. Graphics applications can share system memory and use fast on-board memory for real-time processing between the graphics card and the computer’s memory. This ultimately increases the affordability of ATI’s RADEON® graphics technology.
http://www.ati.com/technology/hypermemory.html
The revolutionary TurboCache technology utilizes the additional bandwidth of the PCI Express graphics bus to reach higher levels of graphics performance than traditional video memory solutions, delivering the performance and features you expect from NVIDIA graphics hardware. By allowing the graphics processing unit (GPU) to share the capacity and bandwidth of dedicated video memory and dynamically available system memory, TurboCache turbocharges performance and provides larger total graphics memory.
http://www.nvidia.com/page/turbocache.html
Here Are the GPU Specs Direct From Dell
So, having said that....
If you have 512MB RAM, go for the smaller 128MB X600. If you have 1GB you can get the larger 256MB GPU.
EDIT: If you notice from the Dell link it says
128MB (32/128MB dedicated/shared) memory
Dedicated means it will NOT take from the system memory, so, if you play alot of games the higher the dedicate the better. If you're not a big gamer or don't care about the graphics of the few games you play, then, it doesn't really matter.
My girlfriend got a Dell with the Intel IGP (Intergrated Graphics Processor) 1GB RAM and with up to 256 Shared Memory for the graphics and it will play anything up until Counter-Strike.
I hope this helps you.
Lol, you're welcome.
Just read my edit for some perspective on how the different GPU's will run your games...
Oh, and just F.Y.I the GPU she has is the Intel Extreme Graphics Media Accelerator 950 with the 224MB Shared not the 256MB like I thought, lol. Sorry.
hmm, ok. both cards are pretty much the same.
the ati had more On Board Memory Data.. whatever that is and the NVIDIA card has faster memory...
ooh what about drivers? that could make a difference right?
Drivers aren't really an issue a whole bunch.
In my opinion the ATi drivers are bloatware and take up alot of resources while the nVidia drivers are pretty clean.
You'll find alot of people who like one driver better then the other, but in terms of performance, there really wont be that big of a difference.
ok. thanks again bud. I think ill be going with the Nvidia card. all i do is play online poker and surf the web anyway.. ooh i play World of warcraft but ill probably be quitting soon hehe
